TwinTurbo.NET: Nissan 300ZX forum - That is with turbos that have stock activators
Fast300
on June 09, 2008 at 10:12 PM
Re: Stock boost is 9.5 PSI how do you get that with Z1 GT525
posted by FuerGrissa
on June 09, 2008 at 10:02 PM
set to stock specs.
Check your boost with an accurate gauge.
If your profile is up to date, and you have stock injectors, you need higher flowing injectors.
in what order would you investigate the source of detonation
FuerGrissa
21:27:53 06/09/08
You can run codes without a reader ...
Guapo
21:45:17 06/09/08
Thanks, I had read that but wasn't sure I understood
FuerGrissa
21:55:45 06/09/08
It saves codes forever till cleared, pause between codes.
Fast300
22:01:30 06/09/08
Thanks, I'm always scared of getting in over my head,
FuerGrissa
22:03:53 06/09/08
Naa, that is what this forum is for, to help. (n/m)
Fast300
22:14:59 06/09/08
Check engine light stays off = no codes?
FuerGrissa
11:54:51 06/10/08
Stock boost is 9.5 PSI how do you get that with Z1 GT525's? (n/m)
Fast300
21:57:42 06/09/08
FuerGrissa
22:02:12 06/09/08
That is with turbos that have stock activators -
Fast300
22:12:43 06/09/08
agreed (n/m)
Guapo
22:18:07 06/09/08
I'd Like to get larger injectors down the road, but
FuerGrissa
22:22:44 06/09/08
Oh no, 14 psi with STOCK turbos, not GT525's (n/m)
Fast300
22:38:17 06/09/08
2nd. At 14 psi, the GT525's flow much more air.
MixManMash
15:15:23 06/10/08
I am not runing lean,FuerGrissa has the problems not me. (n/m)
Fast300
15:40:56 06/10/08
I know that. I was merely commenting as an addition to your
MixManMash
16:45:31 06/10/08
